question about flywheel.
I just received my ist gen b16 longblock yesterday, in place of where the flywheel mounts, there is a sliver disc about the same size as the flywheel, but has no teeth to grap the starter and has holes all over it. It looks like a piece of swiss cheese. what the hell is that?
The motor you received is from an automatic car. To be perfectly honest with you I forgot the name of the part you are mentioning. I am sure somebody on this board knows the name of it.
I have heard rumors (not sure if it is fact) that the automatic B16s have less aggresive camshafts. Can anybody confirm this?
-kenji
-kenji
And yes, auto B16 cams are very weak. You'll want to upgrade as soon as you hit VTEC.
Guest
Posts: n/a
so i can just take off the piece of metel swiss cheese and put my 5 spd flywheel and clutch on right?
As Kenji mentioned, yes, you can.
BUT!!!!!!!!!!!!!
Do NOT forget to change the bolts that attach the flywheel to the crank, as the AUTO uses a shorter bolt. You'll need to get the longer bolts ment for the manual transmission.
THIS IS IMPORTANT
not too much fun and not a lot of pull up top get some ctr or itr and your set... up grade the springs and retainers cuz ive heared they suck too
