pulling out the motor........
Old Feb 15, 2002 | 08:10 PM
MugenGTR's Avatar
Default pulling out the motor........
When you guys pull out the motor where do u bolt the chain that goes onto the hoist? I see most people bolting the chain to the header and intake manifold bolts but some people bolt it to the engine mounts while others bolt it to their valve cover bolts. what the "right" way of bolting on the chain?
Old Feb 15, 2002 | 08:18 PM
Kamin's Avatar
Default Re: pulling out the motor........ (MugenGTR)
dont bolt it there.
this is what i did
on the back of the head behind cylinder #1 there is a hole for a 14mm bolt. get a strong one and an engine lift chain
for the other bolt i used my starter bolt (the thick one)
worked great
Old Feb 16, 2002 | 08:43 PM
MugenGTR's Avatar
Default Re: pulling out the motor........ (KAMiN)
uh............. so thas how EVERYONE else does it?
Old Feb 16, 2002 | 09:17 PM
jonnyc's Avatar
i cant believe there is not more responses here
what a joke i wish i could help you but i havent done mine yet, damnit there has to be a 1000 people who have done b series swaps on here and only one person replies
what a joke
Old Feb 16, 2002 | 09:25 PM
bruthaboost's Avatar
used the hook from a civic or accord that fits behind cyl #1 like previously mentioned and the tranny bracket that the helms suggested.
Old Feb 17, 2002 | 07:55 AM
ImportechPerformance's Avatar
Default Re: pulling out the motor........ (b18bpwr)
What i did is that i used the motor mounts, and wrapped the chain around the bolts and on the driver side i wrapped it around the motor mount and was just carefull that it wouldnt slip out. Doing it this way it only took me and my friend around 15min to just pull it out(that was kinda good considering it was our first time pulling out a motor). But I had to do them one at a time, and also make sure you have a good jack under neath the motor its a big help.
Old Feb 17, 2002 | 09:19 AM
bryant's Avatar
Default Re: pulling out the motor........ (MrPimpon)
No chain here. I just got one of those tow ropes, the heavy duty kind. Strapped it around the trany motor and the mounts. And lifted that beast out.
Old Feb 17, 2002 | 09:28 AM
Kamin's Avatar
Default Re: pulling out the motor........ (CR-X)
if your chain is long enough use the tranny bracket
mine wasnt thats why i used the starter bolt.
Old Feb 17, 2002 | 03:15 PM
Suprdave's Avatar
1 Bolt into a Trans Bolt Hole
1 Bolt into the bolt on the back of the head
Suprdave
Old Feb 18, 2002 | 07:18 AM
Honda4CX-T's Avatar
This is the correct procedure.
However you can also slide the engine out the bottom, by jacking the car off the engine (off course after removing the engine mounts, and be sure to place and old tire for the engine to sit on or a small pallete).
By the way this is the fastest way to remove your engine and replace the engine with out an engine hoist guaranteed.
Koko4
16
Dec 25, 2013 05:42 PM
Potential2nr
Jan 17, 2012 03:47 PM
spidermancivic
Aug 11, 2007 08:17 AM
DARKTEG_
Oct 9, 2006 08:32 PM
spidermancivic
Oct 5, 2006 10:10 PM
