Problem
Old May 4, 2012 | 09:02 AM
James Perkins's Avatar
Icon6 Problem
I have a p72-2 head and the bottom half I got is out of an 04 crv! I'm building the engine and was wondering what head gasket to use! Also the engine when done is going in a 95 del sol, will the trans mock up right to the engine or will I need a new trans?
Old May 4, 2012 | 09:16 AM
kyden's Avatar
Default Re: Problem
there's no way you have a k series bottom end and a gsr head.
Old May 4, 2012 | 09:22 AM
Tkrizz's Avatar
Default Re: Problem
I think OP must be mistaken about the year of his block. It's more than likely a B20. We would need more information on your build sir.
Old May 4, 2012 | 09:53 AM
Tkrizz's Avatar
Default Re: Problem
If your planning to do a B20 vtec build with a stock bore you will want to use the B20 head gasket.
Old May 7, 2012 | 02:55 AM
Default Re: Problem
It's a b20z bottom out of a crv and a p72-2 head, need the gasket
Old May 7, 2012 | 03:30 AM
Dc4LsTeG's Avatar
EK9
Default Re: Problem
Yea your block isn't out of an 04 crv. I'd get the b20vtec head gasket from golden eagle
As for the trans, what engine/trans is in the car right now? B or D series?
Old May 14, 2012 | 04:17 AM
Default Re: Problem
It's a d series that's in the car now
Old May 16, 2012 | 09:09 AM
thid92's Avatar
can I haz?
Default Re: Problem
you need a B-series transmission and go with the HG from GE.
Kanagias
16
Sep 27, 2015 04:27 AM
BigDare23
Aug 11, 2009 05:22 AM
kpjo4
13
Aug 4, 2009 01:30 PM
God-Driven
Feb 6, 2008 05:35 PM
motormike40
Apr 1, 2007 08:14 PM
