which power steering pump/ bracket for lsvtec into a DC2.....
Old Sep 15, 2004 | 03:13 PM
jamessh1's Avatar
Default which power steering pump/ bracket for lsvtec into a DC2.....
hey guys, i had my lsvtec converted a few weeks back and have been running without power steering since the upper ls PS bracket does not connect to the b16 head. I ordered a upper power steering bracket for a vtec head, and the bracket will not work properly with the power steering assembly. what power steering pump/brackets are required in a 94-01 integra?
Old Sep 15, 2004 | 06:59 PM
smart monkey's Avatar
Default Re: which power steering pump/ bracket for lsvtec into a DC2..... (jamessh1)
that is weird you should be able to use the upper vtec one and reuse the ls one on the bottom
Old Sep 16, 2004 | 08:19 PM
-KangaRod-'s Avatar
Default Re: which power steering pump/ bracket for lsvtec into a DC2..... (smart monkey)
bump. The vtec one bolts to the head, but I can't seem to get it to fit the pump.
Old Sep 17, 2004 | 05:49 AM
-KangaRod-'s Avatar
I'm trying to get to the bottom of the mystery here guys. The wierd thing is, the GsR, THe ITR, and the Ls all have different upper power steering brackets (56997-P73-000; Type R, 56997-P72-000; GsR, 56997-P54-010; LS) but the GsR and Ls have the same lower bracket (56994-P54-000) while the Type R has one specific to its car (56994-P73-000). Dunno if that helps any, but it leads me to believe you need the upper and lower ITR specific PS brackets.
Old Sep 17, 2004 | 11:40 AM
acy76's Avatar
Default Re: (-KangaRod-)
Keep us posted. I am going to be dealing with this issue soon myself -- although in a 1991 Integra. Maybe it will be different yet again for me...
Old Sep 17, 2004 | 12:29 PM
-KangaRod-'s Avatar
The debaucle goes even deeper. A 92 GsR has a different upper (56994-PR3-000) than a 92 Ls (56997-PR4-Q00) but the same lower (56997-PR3-010). They share the same pump however (56110-PR3-040), as do the 00 GsR, LS and ITR (56110-P72-003).
What the hell is going on here?
Old Sep 29, 2004 | 12:03 PM
DarthVtec's Avatar
im doing lsvtec to my dc2, i am using a b16 head, for the power steering bracket i used a gs-r bracket. im sure that you could also use a b16 ps bracket, it is a b16 head right? im know the gsr will work cuz thats what im using, the b16 ps bracket, im not 100%.
Old Sep 29, 2004 | 04:18 PM
what year teg do you have? we know the bottom is all the same. I am thinking if you get the bracket to match the year and ps pump you have that would do the trick
Old Sep 29, 2004 | 07:56 PM
acy76's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smart monkey &raquo;</TD></TR><TR><TD CLASS="quote">what year teg do you have? we know the bottom is all the same. I am thinking if you get the bracket to match the year and ps pump you have that would do the trick</TD></TR></TABLE>
After doing some research, I think this is right. There are (I believe) 2 pump styles -- the older V-belt style, as found on the G2 Integras, and the newer ribbed-belt style. Since I am running the older style pump, I need an upper bracket for that pump that fits the B16 head -- 92-93 GSR fits the bill.
Old Oct 1, 2004 | 08:18 AM
DarthVtec's Avatar
i have a 94.
Old Oct 4, 2004 | 08:18 AM
-KangaRod-'s Avatar
any updates on this situation?
If he uses the 99 LS pump and upper, it doesn't bolt to his VTEC head. Does he need a vtec pump and upper?
Old Oct 4, 2004 | 08:45 AM
Default Re: which power steering pump/ bracket for lsvtec into a DC2..... (DarthVtec)
if you have a 94 then I would suggest you get a 94-95 gsr ps upper bracket and reuse the ls lower.
MyEfSi2Slow
May 3, 2011 10:28 AM
yozsi
May 30, 2008 07:56 AM
Takumi Fujiwara
Jun 1, 2005 06:31 PM
Skookem
Feb 11, 2005 02:01 AM
not7fifteen
Apr 30, 2002 10:26 AM
