Possible Ls-Vtec setup
Old Jun 4, 2004 | 07:42 AM
SlowGreenEJ's Avatar
Default Possible Ls-Vtec setup
I am beginning to lean toward this setup:
-ls block= itr pistons/rods, stcok crank,
-B16 head= skunk2 stage2 cams, itr springs with portflow inners\retainers and
good header
-Tranny= Si
I will also be getting the oil lines from The Whipfactory (Superdave726 aim)
Anything else I should consider? Looking for something to have fun with but it will be my daily driver.
Not too sure about the stage 2 cams but, any other opinions will be greatly appreciated.
BTW: it's going into a 94 coupe
Thanks guys
Jon
Old Jun 4, 2004 | 09:23 AM
Anybody?
Old Jun 4, 2004 | 11:19 AM
ScottFern's Avatar
Default Re: (redrex02)
If it ain't a GSR Turbo then its ****.
You heard it here first folks
Old Jun 5, 2004 | 09:38 AM
ChillOutWayne's Avatar
Default Re: (ScottFern)
Go Go Gadget Search Button!! theres 5,000 threads on this ****, including 129 other things u need to accomplish this install safetly and reliably.
Old Jun 5, 2004 | 02:08 PM
What are you a moderator now, thanks!
Old Jun 5, 2004 | 07:42 PM
no problem, i do wat i can
Old Jun 5, 2004 | 07:52 PM
hondaguyef's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ScottFern &raquo;</TD></TR><TR><TD CLASS="quote">If it ain't a GSR Turbo then its ****.
You heard it here first folks </TD></TR></TABLE>
If you ain't ALL MOTOR you ain't ****..........BITCH!!!!!!!
Old Jun 5, 2004 | 09:47 PM
ScottFern's Avatar
Default Re: (hondaguyef)
[sarcasm]If it ain't a GSR Turbo then its ****.[/sarcasm]
Old Jun 5, 2004 | 10:30 PM
god im glad everyone is finally catching, on...its about time
Old Jun 6, 2004 | 10:26 AM
EIT_certified's Avatar
Default Re: (ChillOutWayne)
gsr head will have more compression. don't forget a type R oil pump and you'll have to get a knock sensor tapped in unless it is grounded out or your ecu is chipped/programmed not to use it.
Old Jun 6, 2004 | 10:54 AM
DonF's Avatar
Default Re: (sheemo3)
You cannot use "R" rods on an LS crank.
Old Jun 6, 2004 | 10:59 AM
I3ackfire's Avatar
Default Re: (DonF)
Your gonna want to use the LS stock rods, just get them shot peened, and arp rod bolts. You will also need to shave 1mm off of them to fit the ITR pistons properly!
Old Jun 6, 2004 | 12:35 PM
https://honda-tech.com/zerothread?id=887352
Modified by redrex02 at 9:53 PM 6/6/2004
Old Jun 6, 2004 | 12:51 PM
ScottFern's Avatar
Thats what I have to say about Ls-Vtec!!!
Old Jun 6, 2004 | 01:08 PM
Ok new list...
-ls block= itr pistons/LS rods, stcok crank,
-B16 head= (skunk2 stage2 cams?), itr springs with portflow inners\retainers and
good header
-Tranny= Si
Sound better?
Old Jun 6, 2004 | 07:10 PM
SkRiBLaH's Avatar
get omnipower valvetrain and buddy club spec III cams... and good header = today/hytech/smsp/comptech RACE (NOT TIG)
and oh yes read the signature please!
Old Jun 6, 2004 | 09:12 PM
Default Re: (SkRiBLaH)
https://honda-tech.com/zerothread?id=501372
click this link, about half way down is a copy off of TeamIntegra.net about a guy fully experience with this setup, highlights advantages and disadvantages and parts and a whole lotta ****.
overall it seems if a reputable shop doesnt do it, it seems iffy. also in that article they discuss machine work that has to be done that even i was unaware of, such as redrilling holes for the dowel pins cause the VTEC and LS heads and blocks dont line up, and that includes both oil and coolant passageways. It can be a decent setup if done right, but as that article discusses, its not in the least so much the parts u use, but who does the installation and preparation, and how much money you are willing to spend. i figured id throw in some "useful" and unprejudice info in here. either way, money is money, and will eventually end up in any of our motors anyway. good times
Old Jun 6, 2004 | 10:41 PM
Combustion Contraption's Avatar
you want opinions? Get CTR/ITR cams, which will probably make the most power with your setup because you wont want to be revving to oblivion. Get hondata and get it tuned.
Old Jun 7, 2004 | 11:40 AM
DAredteg's Avatar
why not use ctr pistons i had those in my ls/vtec made a big diff. also spray some juice in it
Old Jun 7, 2004 | 02:08 PM
BigBodySmith's Avatar
get forged internals and balance the bottem end, run 12:1 compression with the stage 2 cams, and yourmotor will have the potential to be right there with the gsr turbo guys, if not in front. all motor is the way to go!!
93egSLEEPER
11
Sep 16, 2010 10:49 AM
turbo_d
Jan 10, 2010 07:28 PM
Pandahatch
10
Jan 18, 2006 08:25 AM
soon2b
Dec 11, 2003 09:27 AM
LSVTEC408
Jun 10, 2002 06:52 PM
