is it possible to get a bad ecu
Old Mar 22, 2004 | 02:26 PM
alexb16hb's Avatar
Default is it possible to get a bad ecu
hey guys what do you think. I just swapped in a b16 into my 95 civic cx. hooked everything up pulled the neg battery cable to clear the codes. now before i even started it I checked the codes to see if they were cleared and it is giving my a code (one flash). Is my ecu that I got with the motor shot or did the code not clear. What s up with this.
Old Apr 2, 2004 | 12:00 AM
Del_Slowest's Avatar
Default Re: is it possible to get a bad ecu (alexb16hb)
o2 sensor is bad or unplugged
Old Apr 2, 2004 | 12:29 AM
Downey's Avatar
a slow flash or quick flash?
probably a wiring issue or somthing. you could always try a different ecu.
SolScifen
May 19, 2013 11:35 AM
dc2_97teg
Nov 27, 2007 10:30 PM
initialR
Jan 10, 2005 10:06 AM
gary201147
Mar 7, 2004 01:21 PM
kim_2_da_chee
May 30, 2003 06:18 PM
