Poor Mans Type R
Hey H-T. I've been looking around for awhile and I need a little help. I have a 00 si and I wanna switch out the B16 block for a B18C block. I'm lookin for like little things that I'll need, maybe a write up. Like if I'll need different motor mounts. I know I'll need different pistons, cams, ecu. If anyone has done this or can point me in the right direction itd be appreciated. I'm really looking for somethin chasis specific to the em1 for information.
really...cuz ive searched many many times. feel free to prove me wrong by showing me an example of someone doing this swap in an 00 si.
otherwise, zip it.
otherwise, zip it.
Ok then,
Mounts are the same.
You will need to get an obdII gsr block for the oil pump crank sensor.
Other than that there is nothing different. Just a poor mans with the obdII crank sensor.
The alternator and dizzy have different plugs than the OBDI does.
If you were really interested in finding out you would search poor mans R and then search the difference between OBDI and OBDII.
eghatch4sale
Sep 30, 2009 07:03 PM
