poor mans type r
Old Oct 16, 2004 | 03:58 PM
gSIr's Avatar
Default poor mans type r, piston and rod choice
I am building a poor mans type r with this setup
95 gsr block
gsr crank
p30 pistons
99 b16a2 head
My question is, since i am using the p30 pistons, can i use those rods or do i have to use the gsr rods, or is there any difference?
Modified by gSIr at 12:21 AM 10/17/2004
Old Oct 17, 2004 | 02:03 PM
gSIr's Avatar
Default Re: poor mans type r, piston and rod choice (gSIr)
bump
Old Oct 17, 2004 | 02:59 PM
rsbad454's Avatar
as far as i know, you have to use the GSR rods....
Old Oct 17, 2004 | 03:40 PM
gSIr's Avatar
thanks, does anyone know if i need to upgrade my fuel system at all besides the pump?
should i use gsr head bolt torque specs or integra type r torque specs?
Old Oct 17, 2004 | 04:46 PM
rsbad454's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gSIr &raquo;</TD></TR><TR><TD CLASS="quote">thanks, does anyone know if i need to upgrade my fuel system at all besides the pump?
should i use gsr head bolt torque specs or integra type r torque specs?</TD></TR></TABLE>
Vtec fuel pump will be good and type r and GSR head torque should be the same. If you use factory bolts use factory specs, if you use ARP bolts/studs use their specs.
Old Oct 17, 2004 | 04:59 PM
Katman's Avatar
yes, you NEED to use GSR rods with your P30 pistons if dumping everything into a B18C block. If using a B16A block, then you'd use B16A rods. B18C blocks have a 7mm taller deck height thats why they have longer rods.
What's model HOnda do you own?
Old Oct 17, 2004 | 05:15 PM
gSIr's Avatar
thanks everybody, i finished ripping the b18c1 block apart today and i'm gettin the p30 pistons tomorrow, i can't wait to finish it. btw the reason i'm building this is because i melted piston number 4 with my turbo setup.
t3/t4
255 walbro fuel pump
12:1 fmu
vafc
99 ebp si
Modified by gSIr at 10:11 PM 10/17/2004
Old Feb 13, 2005 | 05:01 PM
FormulaGSR's Avatar
get forged pistons
Old Feb 13, 2005 | 06:44 PM
Bense's Avatar
Default Re: poor mans type r, piston and rod choice (K@man)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by K@man &raquo;</TD></TR><TR><TD CLASS="quote">yes, you NEED to use GSR rods with your P30 pistons if dumping everything into a B18C block. If using a B16A block, then you'd use B16A rods. B18C blocks have a 7mm taller deck height thats why they have longer rods.
What's model HOnda do you own? </TD></TR></TABLE>
wow, it's interesting to think that the only difference is 7mm. That 7mm ends up costing you so much more!
kylesmith3251
Oct 29, 2011 08:12 PM
honda2ksi
Jun 23, 2010 02:07 PM
superfuji57
Sep 25, 2002 07:31 PM
willyboyK20
May 12, 2002 06:38 AM
