PCT(CTR) pistons & CTR cams in LS/Vtec?
Old Apr 17, 2002 | 05:33 PM
InfamousRS's Avatar
Default PCT(CTR) pistons & CTR cams in LS/Vtec?
Would there be enough room between the valves & piston? I read on H-T a while back that there it not enough room so piston slap occurs, it that true?
Old Apr 17, 2002 | 05:45 PM
InfamousRS's Avatar
Default Re: PCT(CTR) pistons & CTR cams in LS/Vtec? (BLK94RS)
And also, what is a good valve train upgrad on a B16A2 head to support the CTR cams?
Old Apr 17, 2002 | 07:50 PM
allmtr's Avatar
there WILL be enough valve to piston clearance. the ctr pistons were made for high lift vtec cams so there should be no problem. maybe your thinking of ctr cams and stock LS pistons. now if you mill the head and get a thinner head gasket, then you may have problems. but why would you want to do that, with the ctr pistons your CR will be like 12:1 give or take a few.
for the valve train upgrade, get duel springs and titanium retainers. or get it of the type-r.
Old Apr 17, 2002 | 08:40 PM
InfamousRS's Avatar
Default Re: PCT(CTR) pistons & CTR cams in LS/Vtec? (allmtr)
What exactly are differences between the ITR and CTR cams? How much duation and lift to the 2 have? How high will they make power to?
Oh, will the ITR outer springs, with portflow inner springs and titanium retainers be suffeceint for the CTR cams?
And what about bronze valve guides, are they worth haveing?
[Modified by BLK94RS, 9:46 PM 4/17/2002]
Old Apr 17, 2002 | 09:51 PM
ExospeedAMcrx's Avatar
we have the exact same setup on a motor we just built for a customer. LS VTEC with CTR pistons with a GSR head, unmilled, with CTR cams.
runs perfect! You shouldnt have any problems
Wil
Old Apr 17, 2002 | 10:12 PM
InfamousRS's Avatar
Default Re: PCT(CTR) pistons & CTR cams in LS/Vtec? (exospeedAMcrx)
Wil
Is that with stock rods? If so, what did you have done to the rods to prepair them for the high revs? Shot-peening? ARP rod bolts?
Did you dyno it? How much power is it making?
What are you running for a ECU?
Do you know what the CR came out to be with the b18c1 head? Im going to be using the b16a2 head, and CTR .25 over pistons so the CR will be right at 12.0:1, to be exact 12.028963626657404:1
Old Apr 18, 2002 | 10:32 AM
CTR pistons.. still using shot peened stock rods with ARP bolts.
ECU is a P28 chipped
Im assuming 12:1 compression with the GSR head.
Haven’t seen dyno results yet on this particular one but it did hit a 13.4 at the track untuned. It was put in an 89 Si.
Ive seen similar setups dyno at around 195HP to the wheels. But I guess can range from 185-200. depending on the ECU used and if dynoed, and if using a V-AFC for tuning.
Wil
Old Apr 18, 2002 | 11:25 AM
infamousALLMTR's Avatar
hondata baby all the way.... have you guys ever put one of those on a customers ride?
Old Apr 18, 2002 | 09:22 PM
speeddave's Avatar
Default Re: PCT(CTR) pistons & CTR cams in LS/Vtec? (infamousRRH)
hey wil, i am building an ls/vtec and i want to change the valvesprings... i was thinking comp cams, just cause i can get a good deal on them, or if there cheaper i was thinking usdm type r ones. the cams are presently stock, but if i find a set of itr/ctr ones i want to stick those in. would these springs be sufficient? also when i was checking out your site you have a 89si w/a ls/vtec... he runs 13.4's? what is the setup on that car if you don't mind me asking. i have a 90 and i'm curious as to what kind of times my combo could accomplish. thanks, props on the sohc project, i plan to do that with my si motor
Old Apr 20, 2002 | 05:09 PM
JaeOne3345's Avatar
Default Re: PCT(CTR) pistons & CTR cams in LS/Vtec? (speeddave)
http://www.bojangs.com/calculator/
EusebioSam19
Mar 18, 2011 05:52 AM
DA3
Apr 7, 2009 11:37 AM
Driven
14
Apr 4, 2004 10:58 PM
Dammit_Dan_954
Nov 22, 2003 12:27 PM
P1mpSlap
Jun 4, 2003 08:09 PM
