ODB1 - ODB0 Conversion?
is your hatch an Si? If so then you can do the following without converting from DPFI to MPFI. If its a DX or STD model (DPFI) then you will have to convert to MPFI first.
Distributor : couple of options 1. use your current distributor or an 90-91 LS integra dizzy and you will have to modify the legs (the part that the three 12mm bolts go through to bolt to the head) and use a timing gun to set timing.
2. Find a OBD0 b16a distributor on ebay or on this board.
Injectors : use your current injectors from your Si (if it is an Si).
Motormounts : Hasport.com, Placeracing.com
Axles : 90-91 Acura integra 5spd axles any model
Ecu : PR3 B16A dohc vtec ecu
Wiring : wire up vtec solenoid, vtec pressure, and knock sensor
Optional : convert to obd1 using obd0-1 harness and use the b17a dizzy, injector and a P30 or P61 ecu.
It currently has a DOHC ZC, I've all ready wired the MPFI this December. I have the mounts and axels all ready.
Is it easier or more economical to step up or step down OBD levels?
[Modified by ZC_CRX, 7:04 PM 3/27/2003]
locashracing has made an OBD0>OBD1 harness...i just wonder about the injectors and all the resistor pack crap you have to convert over, since the OBD0 injectors are peak hold type.
You can keep your non-obd (si) injectors when converting to obd1, just keep the resistor pack. That way, you don't have to change injector plugs. If you want to run obd1 injectors, loose the resistor pack and change the plugs. Some peeps like to keep the resistor pack so they can use 450cc mits injectors in a turbo setup. They are low impedance and require the resistor pack.
HTH
chris
HTH
chris
I'm dropping a B17 into my 90 hatch.
s2kkk
Feb 18, 2004 06:32 AM
