obd2 --->obd1
i put a 2000 h22 in to my 99 civic EX, if i convert the ecu to an obd1, do i have to get a distributor from an 92-95 prelude vtec so that it will be obd1 also? any help would be great, thanks guys.
You want to make the whole engine OBD1 or you just want to run an OBD1 ecu? If you just want to run the ecu then you just need the conversion harness that plugs into your stock ecu plugs then plugs into an OBD1 ecu.
Thanks, J
Thanks, J
i have the conversion harness, i have it plugged in to my harness and my jdm p13. the car will only ... will not turn over all the way. i just want the thing to run...
oh and can anyone tell me how to take the immobilizer off of the 2000 prelude ecu?
