OBD2 IAB question
Old Sep 10, 2002 | 09:22 AM
1 speedstar's Avatar
Default OBD2 IAB question
i have a 00 gsr and my car is a 96 civic. i dont have the original plug for the IAB since i didn't get a harness with the motor. i picked up another 2 wire plug, the same plug type for the vtec pressure switch.
I know one of the wires will run straight to my ecu at A26, but where does the other wire run to? i've read the other thread on OBD1 IAB, but i didn't want to post my question in there since it might get off topic from the creators post. can anyone help me out? thanks in advance
Old Sep 10, 2002 | 09:43 AM
92sleepR's Avatar
New User
Default Re: OBD2 IAB question (primo ek)
Ground. The OBD2 ecu's use a positive trigger signal.
Mike
Old Sep 10, 2002 | 12:16 PM
Default Re: OBD2 IAB question (92sleepR)
does it matter which wire goes where?? can just run either one to the ecu and the other one to a ground and ill be good? thanks
Old Sep 11, 2002 | 01:03 PM
ttt i need a definite answer
Old Sep 11, 2002 | 01:22 PM
Malachi's Avatar
you dont ground it, you run it to a switched 12 volt sorce. as far as which is which i couldnt tell you. i had to add that plug too if it doesnt close when you turn the car on then pull the little pins out and switch them real quick.
Old Sep 11, 2002 | 10:07 PM
Default Re: OBD2 IAB question (Malachi)
ok.. now im getting mixed answers... can someone pls clarify this??
Old Sep 13, 2002 | 12:37 PM
Malachi's Avatar
ok, with the denso label on the canister pointing towards the front bumber. the wire closest to the front goes to a 12+V switched wire. any yellow/black. i used one off the injectors. the other goes to the ecu. mine works so thats how i would go about it.
dstah
May 4, 2009 04:57 PM
d15vtec94
Dec 4, 2004 08:46 AM
95excoupe
Nov 17, 2004 11:27 AM
tiresmoke
Apr 19, 2004 05:12 AM
5 Skware
Jul 30, 2003 03:28 PM
