OBD2 car, OBD1 block
Old Sep 15, 2002 | 06:02 PM
Ehron's Avatar
Default OBD2 car, OBD1 block (rest of engine obd2) Concerns?
I was looking to pick up an obd1 block to go with my obd2 b16a. Will I have any problems? Thanks.
[Modified by Ehron, 3:04 AM 9/16/2002]
Old Sep 16, 2002 | 04:40 AM
Ehron's Avatar
Default Re: OBD2 car, OBD1 block (rest of engine obd2) Concerns? (Ehron)
___
Old Sep 16, 2002 | 05:27 AM
Trey's Avatar
25 Year Member
Depends on the ecu you use.
OBDII ecu looks for the crank fluctuation sensor which is mounted behind the crank pully and gear.
You can swap it off the OBDII block if you plan to keep using the OBDII ecu.
Old Sep 16, 2002 | 05:53 AM
Ehron's Avatar
Default Re: OBD2 car, OBD1 block (Trey)
Great! Thanks for the info Trey.
Old Sep 20, 2002 | 06:57 PM
Solid Alibye's Avatar
Default Re: OBD2 car, OBD1 block (Ehron)
although to swap the crank sensor, you'll need an OIL pump off an OBD II motor. ......have fun swapping that.....
You'd be better off using an OBD 1 ECU w/jumper harness, so you don't have to worry about the OBD II sensors you don't have on the OBD 1 motor.
Old Sep 22, 2002 | 09:51 PM
civic23g's Avatar
Default Re: OBD2 car, OBD1 block (Solid Alibye)
Thank you for clearing that up for me as well. I have a OBD2 civic with a with a OBD1 GSR motor about to go in and was not sure how hard it was with that crank fluc. sensor install. Well OBD1 here I come.
honda2ksi
Jun 24, 2010 01:45 PM
strictly.business
Nov 25, 2006 09:05 PM
b20_ed
Nov 10, 2005 12:25 PM
aw1234dude
Dec 7, 2004 01:27 AM
Civic
Dec 14, 2003 11:51 AM
