An OBD1 to OBD2 wire harness ecu conversion
Old Nov 13, 2002 | 01:25 PM
EKHappy's Avatar
Default An OBD1 to OBD2 wire harness ecu conversion
Anyone know where I can get one? I know there is the OBD2 to OBD1 conversion all over the net. But I keep hearing people say they also have the OBD1 to OBD2 conversion harness also. If so where can I get one?
I know I guy in town that can do the wiring on a OBD2 motor to OBD1 car using an OBD2 ecu without check engine light problem. But he's just too busy..
Old Nov 13, 2002 | 01:33 PM
poison's Avatar
Default Re: An OBD1 to OBD2 wire harness ecu conversion (orientalboy)
You can make your own, i would IM YumVTEC about that, or you can purchase one from Skunk2 as well.
Old Nov 13, 2002 | 01:37 PM
Kataku2K3's Avatar
Default Re: An OBD1 to OBD2 wire harness ecu conversion (poison)
Yea, just make your own.... it's cheaper About the guy wiring an OBD2 ECU into a OBD1 car.... So does he bypass the secondary oxygen sensor and crankshaft speed fluctuation sensor??? Or does he just install a new oil pump with a CKFS and secondary O2.... If that's the case then i see no point in it.. Just get an OBD1 ECU.. Latez
[Modified by JDMspecEG6, 5:31 PM 11/13/2002]
Old Nov 13, 2002 | 05:09 PM
0gsR's Avatar
New User
Default Re: An OBD1 to OBD2 wire harness ecu conversion (JDMspecEG6)
email kenji at kenji211@tampabay.rr.com. he made me one. no engine check light. fixed my infamous idling problem as well.
uses0ap
Feb 17, 2009 01:16 PM
NOman0608
Jul 26, 2007 10:28 AM
BLUE EH3
May 13, 2005 08:19 PM
98civicEX
Aug 12, 2002 07:15 PM
Gmedalion
Jul 10, 2002 07:56 AM
