obd1 and obd2 questions
Can you use an obd2 distibutor with an obd1 ecu? I swapped heads on my 95' civic with the head and distributor from a 97' I'm getting engine codes 1 and 4 could this be my problem, thanks.
-Derek-
-Derek-
yes you can..if have an OBD2 Honda (96+) and you're using an OBD1-OBD2 ECU jumper.
code 1 is 02 sensor
code 4 is CKP sensor (crank shaft Position)
You should reuse your 95 civic's distributor with the setup you're doing. It will make life for you and the rest of us a lot easier
code 1 is 02 sensor
90Rexx
15
Feb 6, 2010 09:20 PM
Spaceballsthelunchbox
Feb 23, 2007 07:22 AM
sweet
Mar 28, 2003 01:16 PM
