OBD1 & O2 sensor
that is correct. obd1 = 1 o2 sensor. u can run a straight pipe with out getting a CEL.
umm..
obd1 ecu is tunable
obd2 ecu is not.
obd1 has less sensors to worry about
obd2 has more. more of a headache.
umm..
obd1 ecu is tunable
obd2 ecu is not.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BI8B »</TD></TR><TR><TD CLASS="quote">will a chipped OBD1 ECU run a CEL?
can i use my stock OBD2 o2 sensor or will i need a OBD1 o2 sensor?
You just need a jumper harness with an OBD1 ecu. All OBD2 O2 sensors are the same.
so all obd1 and obd2 sensors are the same?<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by poison »</TD></TR><TR><TD CLASS="quote">
You just need a jumper harness with an OBD1 ecu. All OBD2 O2 sensors are the same.</TD></TR></TABLE>
you said all OBD2 sensors are the same. so, i'm guessing all obd2 and obd1 sensors are all the same? 4 wire?
yes u can use the obd o2 sensor.
I think what poison meant was that all OBD1 & OBD2a/b 02 sensors are the same, which is totallly true.
When you use a jumper harness to convert OBD2a/b to OBD1, you don't need to worry about any wiring at all. It's all done within the jumper harness. Thats what makes a jumper harness soo coool -- plug n' play!
l1l_r1cky
Feb 28, 2012 01:27 AM
724chris
Jan 23, 2010 07:04 PM
redsolturbo
Jul 23, 2007 07:08 AM
fanoftheb00st
Jun 16, 2007 08:27 PM
