OBD0 - OBDI Question
Alternators - are the connections on an b-series OBD0 & OBDI alternator the same? I replaced the alternator on my b16a - it's good at idle - between 13.6 & 13.85 volts depending on the accessories on. At about 6.5k rpm, the charging light comes on & stays on until the revs drop. I had replaced the old alternator with a 65 amp 91 LS alternator & think that the alternator's just too weak to deal with the VTEC requirements. I'd like to change to a 94 GSR alternator, since they're 90 amps, but need to know if it will plug in!
Thanks,
Eric
Thanks,
Eric
