o2 Sensor + b18b, wiring HELP!!!!!
Old Aug 16, 2003 | 12:34 AM
ransack's Avatar
Default o2 Sensor + b18b, wiring HELP!!!!!
Allright, the last thing I need to do for the swap, is wire the o2 sensor on the cat. I need to know where to wire up the 4 wires on the 02 sensor on the cat to the ECU. I have a Haynes manual, but its showing the wire going different places that I dont know and I dont know of the cat o2 is the secondary or primary (im assuming secondary). thanks for help guys!
//Jesse
Old Aug 16, 2003 | 10:07 AM
ransack's Avatar
Default Re: o2 Sensor + b18b, wiring HELP!!!!! (ransack)
anyone?
Old Aug 16, 2003 | 10:39 AM
VTECVillain's Avatar
Year and model car?
Old Aug 16, 2003 | 12:35 PM
ransack's Avatar
Default Re: o2 Sensor + b18b, wiring HELP!!!!! (VTECVillain)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTECVillain &raquo;</TD></TR><TR><TD CLASS="quote">Year and model car?</TD></TR></TABLE>
durr, sorry
97 LS (b18b) with the 97 LS ECU
its in a 96 civic hatch.
Old Aug 16, 2003 | 06:04 PM
mtber's Avatar
Brother,
You should only have to extend you're o2 sensor plug and plug it into the harness on the distributor side of you're car.
Old Aug 16, 2003 | 06:10 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ransack &raquo;</TD></TR><TR><TD CLASS="quote">97 LS (b18b) with the 97 LS ECU
its in a 96 civic hatch.</TD></TR></TABLE>
The wiring should be there for both O2 sensors since your car is OBDII. The primary O2 sensor plug will be in the engine harness and the secondary O2 plug will be coming down from the floor near the cat.
Old Aug 16, 2003 | 11:49 PM
ransack's Avatar
The wiring should be there for both O2 sensors since your car is OBDII. The primary O2 sensor plug will be in the engine harness and the secondary O2 plug will be coming down from the floor near the cat.</TD></TR></TABLE>
err hah. ok. I did use a 97 EX harness also, but I will jack that ISH up and see what I can find. I extended one set of o2 wires to the header. well ill look tommorrow. thanks
Old Aug 17, 2003 | 01:06 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ransack &raquo;</TD></TR><TR><TD CLASS="quote">I extended one set of o2 wires to the header.</TD></TR></TABLE>
That would be the primary O2 because it's in the upper part of the stock header in the EX so the plug would need extended to reach the location in an LS header.
Old Aug 17, 2003 | 09:29 AM
ransack's Avatar
ok, I read your post over again, and now I get it. there should be another o2 sensor plug coming from the car, and not the harness. I was looking on the harness, opps. thanks. hopefully I can find it.
Old Aug 18, 2003 | 10:19 AM
ransack's Avatar
allrighty, I looked and looked, even tore carpet to search, but I couldnt find that o2 sensor coming from the car. I even searched my Haynes and im coming up with nothing. So where is it?! If it there, I wanna use it, I dont wanna wire it up to the ECU itself...
OK, So im thinking why wouldnt there be a o2 sensor in that spot. I remember how where the 2 o2 sensors were on my 96 CX engine. One was at the end of the header and one at the BEGINNING. So im thinking that my car doesnt have that plug in hanging by the cat, cause the car never had an o2 hookup at the cat. So therefore, it wont be in that spot.
So im thinking I have to now wire it up directly. Can anyone point me in the right direction?
Modified by ransack at 12:53 PM 8/18/2003
Old Aug 18, 2003 | 05:09 PM
ransack's Avatar
bump for help
Old Aug 19, 2003 | 09:54 AM
ransack's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ransack &raquo;</TD></TR><TR><TD CLASS="quote">allrighty, I looked and looked, even tore carpet to search, but I couldnt find that o2 sensor coming from the car. I even searched my Haynes and im coming up with nothing. So where is it?! If it there, I wanna use it, I dont wanna wire it up to the ECU itself...
Modified by ransack at 12:53 PM 8/18/2003</TD></TR></TABLE>
well? anyone?
Old Aug 21, 2003 | 07:41 PM
95hbMatt's Avatar
the plug should be hanging right behind your intake mani....crawl under the car and look up..that's how I found mine..
Old Aug 22, 2003 | 12:27 AM
ransack's Avatar
Default Re: o2 Sensor + b18b, wiring HELP!!!!! (95hbMatt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95hbMatt &raquo;</TD></TR><TR><TD CLASS="quote">the plug should be hanging right behind your intake mani....crawl under the car and look up..that's how I found mine.. </TD></TR></TABLE>
I have that one hooked up! Its plugged to the O2 in the header.
thanks tho, unless theres 2 O2 hookups on an civic EX wiring harness..
Old Aug 22, 2003 | 08:31 AM
95hbMatt's Avatar
thanks tho, unless theres 2 O2 hookups on an civic EX wiring harness..</TD></TR></TABLE>
well if it's an obd2 wiring harness there should be 2 hookups...one on the front left of the wiring harness and one in the rear under the intake mani...i think
Old Aug 24, 2003 | 10:23 AM
ransack's Avatar
allright, I looked and couldnt find a 4wire hookup for the 2nd o2. Maybe im missing it. I see a hookup that does just dangle down towards the o2, but its only a 2 wire plug....thats not it is it?
tomek5x
Jan 21, 2008 09:56 AM
EKRacer
May 1, 2004 09:39 AM
hatchattak
Apr 16, 2004 11:01 AM
Al1exx
Sep 28, 2003 06:08 AM
