NEED HELP ON LS/VTEC EMISSIONS!!
Old Jan 6, 2015 | 07:34 PM
Cristian-_'s Avatar
Default NEED HELP ON LS/VTEC EMISSIONS!!
Hello. I recently just bought a 2000 Civic hatch with an LS/VTEC. The problem is that I need emissions ASAP. The check engine light is on and I don't know what is causing it. I plugged In a scanner but the scanner would not link to the car because it has an OBD 1 ecu. Now I know I need an obd 2 ecu for emissions but I don't know what to get. Also another thing is that when I start the car ut idles very low and bounces around and if im not taping the gas it will die. Once I start driving it the idling is fine. Now I really need to solve these problems, if anyone can help, thank you very much.
Old Jan 8, 2015 | 03:55 PM
hybridmiklo's Avatar
Default Re: NEED HELP ON LS/VTEC EMISSIONS!!
to start, lsvtec will fail the visual test.
Old Jan 8, 2015 | 04:54 PM
HondaPartsHero's Avatar
Technical Hero
Depends on the state you live in. You'll prob throw s good number of emissions codes but you could use a P2T or P30 from a 96-97 del sol with an adapter harness, or a 96-98 P72 with adapter harness or a P73 from the itr with corresponding adapter harness for 96-99
slayersluck
Feb 19, 2005 10:27 PM
silverb18
11
May 7, 2004 10:11 PM
khang77642
Aug 13, 2002 10:05 PM
khang77642
Aug 13, 2002 09:19 PM
