My H22 Update :)
I redid my balance shafts, by lining it up through the maintenance hole. All my attempts to line the rear up by the dot on the gear were futile, because I didn't have the internal gears properly lined up.
What a freakin difference it made!
The car idles like a dream, and even with the a/c on full blast at idle, there's only a HINT of vibration through the dash.
I honestly think it vibrates less than it did when I had the b18b with stock hollow mounts.
I'm very pleased...I was pretty discouraged for a while there, but
Many thanks to laugHin22CX for the post from the Helms manual. It really helped me out.
Also, just for the record, I drove around for a day with the balance shaft belt removed, and I can say without a shadow of a doubt, it does vibrate a whole heck of a lot more at idle than with the shafts engaged. It does rev faster though
Sorry for rambling, I'm just very happy
I'll run her as soon as I get it tuned.
I've also got an exhaust leak that I just cannot fix.
Collector on Jun header is larger than my 'high flow' cat, so no matter what I do, I can't get a good seal at that point. So I'm goign to redo the whole system before I take it.
Plus I'm throwing codes.
I'm still waiting on IAB and EGR plugs from Prospeed as well.
You guys know how it goes
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hot_EH »</TD></TR><TR><TD CLASS="quote">
should of got a new system
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KTeller8 »</TD></TR><TR><TD CLASS="quote">
should of got a new system</TD></TR></TABLE>
Oh I will. Just got a new job....I will be in contact with you Mike as soon as I pay off a remaining debt
