my first DYNO
Maybe some cam gears, something to adjust your fuel (adjustable FPR), over-bored throttle body. These probably won't even amount to a 10-15 hp gain, but if you are planning on turbocharging in the future, you might as well just look at parts that will be compatible with it.
i actualy do have a fpr and will they were dynoing it they dropped it down some which gave me an additional 3 hp but he said its still running a lil rich up top. he said he had it adjusted as low as the fpr would allow it with out taing it all the way off the thread. i figured i would do the TB but i didn't know what one to do. should i get a type r or should i get an aftermarket one? and i didn't know what type of cams to use. like i said i want something that is gonna help me on the na side but will also be good once i go turbo. what cams do you suggest?
sivik-si
Jul 11, 2007 07:48 PM
