mount question
okay i have an eg...bout to do a b-series swap. i know which mounts you are suppose to use from an integra. but the 94-95 ex civic driver mount looks the same as the integra driver mount. Are they the same or not?
i don't think they are the same either. A civic driverside mount usually only has 2 17mm bolts and the integra mount has 2 17mm bolts and 1 14mm. The civic mount may line up and all but that extra bolt is there for a reason. The b series motor does weigh a little bit more than the d series motor but it is a direct bolt up with the integra mounts. You can use the civic upper tranny mount
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsrpwrdhb22 »</TD></TR><TR><TD CLASS="quote">and the integra mount has 2 17mm bolts and 1 14mm. </TD></TR></TABLE>
All three are 14mm. The 17mm is the center bolt the holds the mount to the chassis.
The mount I am speaking of is the 94/95 d16z6 mount...looking at pictures they look the same; both silver with three bolt holes. But if that statement of "they are offset a little different" is true than that is the answer to my question. Can anyone else confirm that, thanks for all of yalls (country) input
Also I know for the 5g civic different mounts were used. For the vx motor (which i have
) The mount is totally different from a d16z6 mount. It is black and has ( damn let me go look real quick) 2 offset holes (not parallel to the mount edge). But I am comparing the lookalike d16z6 mount to the teg mount.
) The mount is totally different from a d16z6 mount. It is black and has ( damn let me go look real quick) 2 offset holes (not parallel to the mount edge). But I am comparing the lookalike d16z6 mount to the teg mount. Thread
brookliner7
Apr 5, 2005 06:44 PM
92civeg
14
Feb 20, 2004 09:35 AM
. I have always used the teg tranny mount as well though.
