easy driver side mount question!!!!!
will this mount from a 94+ integra bolt up to my b16a block?
http://www.imagestation.com/my...bum=1
Modified by 92civeg at 1:32 PM 2/20/2004
Re: easy driver side mount question!!!!! (92civeg)
How much are you willing to spend?
http://www.hasport.com makes quality replacement mounts but they cost about 150.
I believe you use the Integra drivers side mount if you want the 60 dollar stock one.
Any 94+ Integra or A stock B16A Mottor mount would work from 96-98 should work also I do believe. The stock motor mount from for for 92 civic could be used too but it might not be strong enough and you would need to get a solid mount inserts to put in
Solbros Owns Me
Re: easy driver side mount question!!!!! (Spade)
You probably have the 2 hole mount, right?
The Integras use the same mount that the 94-95 D16Z6's have...aluminum 3 hole mount
either find a used one or get a HAsport or whatever
i just want a stock one but im not sure which one i need to use, to be able to reuse my bracket
yeah i have a 2 hole bracket...so i need a new bracket and mount?....
and will a bracket froma 94+ integra bolt up to my b16 block?
and a mount from a 94+ teg bolt up to my frame?
Solbros Owns Me
I don't know about the mount onto the block...
but a Del Sol VTEC B16 mount or just the JDM B16 mount is what you will need.
I think someone was selling one in the classifieds for 30 shipped
Re: easy driver side mount question!!!!! (NonovUrbizniz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NonovUrbizniz »</TD></TR><TR><TD CLASS="quote">Big John Stud...lol</TD></TR></TABLE>
haha
will a 94+ bracket bolt up to my b16a block>>?
haha
If youre throwing a B16A into your EG all the stock mounts work. In that pic thats the bracket, that the mount bolts to. B18Cs use a 3 bolt bracket and mount, but if your B16A has the STOCK bracket then your stock 92-95 civic mounts will work.
