MAP sensor vac lines ???
91 teg, lsvtec, pr3 ecu, nonturbo
I have been getting map and o2 check engine codes, replace the o2 and that is fixed, after jacking around with the map, I notice a line not connected, the vacuum line for the map T's at the sensor one to the map and another somewhere else, where does this line go or should it be going straight to the map sensor, thanks for the help.
getupoffthatthan
Oct 15, 2008 03:20 PM
92hybridAccord
May 4, 2004 11:34 AM
