Help installing map sensor on D16Y8
I need help installing the motorolla 2.5 bar map sensor. I am not sure which sensor on the intake is the stock map sensor. I found a diagram of which wires to wire them into. That doesn't seem like a problem. My main focus is finding the current map sensor and then figuring out which vacuum line connects to the motorolla.
thanks!
thanks!
Re: Help installing map sensor on D16Y8 (RonJ@HT)
Thanks, should i just run a vacuum line from the moto 2.5 to the port under where the stock map is?
Re: Help installing map sensor on D16Y8 (Gunmetal_B20_Hatch)
where is the vacuum line to attach to the motorolla map sensor? or should i just run a line from where the original map sensor came from?
92hybridAccord
05-04-2004 11:34 AM
