MAP Sensor Question/Problem...
Old Aug 17, 2009 | 05:11 PM
97EKCRVtec's Avatar
Default MAP Sensor Question/Problem...
I'm in the process of putting OBD1 B20Vtec into my 97 Civic CX, I've got everything wired up pretty much but I'm lost of what to do about the MAP Sensor. I'm running a B16 Intake Manifold and it has a 2-Wire MAP Sensor, but my CX/OBD2a Wiring Harness has a plug for a 3-wire MAP Sensor..
I figured out that the Red/Green Wire is the Manifold Absolute Pressure Sensor (MAP), the Green/White wire is Sensor Ground (SG1), and the Yellow/Red wire is Sensor Voltage for MAP (VCC1) According to the OBD2a ECU Pin out Schematics. But I can't figure out which 2 of the 3 wires I should use on the 2-Wire MAP Sensor.
My b20vtec was in my 93 Integra which is OBD1 and I looked at the Wiring Diagram from the Haynes Manual and the OBD1 MAP Sensor is 3-Wire as well, So I'm guessing I'm using an OBD0 MAP Sensor?
Does anyone know what I should do or can anyone point me towards a How-To or Diagram?
Old Aug 17, 2009 | 06:04 PM
Garage 808 Hatch's Avatar
Default Re: MAP Sensor Question/Problem...
all B16 map sensors are 3 wire. you have to be looking at the wrong plug
Old Aug 17, 2009 | 07:02 PM
97EKCRVtec's Avatar
Yeaah I was the map sensor wasn't mounted on the motor at all it was mounted on the firewall. It's all good im using the map from my DA Integra
Old Aug 18, 2009 | 11:36 AM
LA_HONDAS's Avatar
thats not the map sensor
all honda/acura map sensors have 3 wires
cleanazcoupe
Engine Management and Tuning
Jul 8, 2009 09:28 PM
tpod
Mar 5, 2007 10:07 AM
Del Sol on Steroids
Nov 22, 2006 12:50 PM
aldong
Oct 8, 2006 06:15 PM
