map sensor code 3
Old Aug 31, 2003 | 07:58 PM
DAMCOOLDAV's Avatar
Default map sensor code 3
Guys i'm throwing a code 3, my map sensor, and it never did it before i did my b16 swap into my 91 GS, but it is now, which is making my idle bad and my fuel super rich. Why would it be doing this now.....i've checked all my vacuum lines there all connected i dont' see any leaks, i'm gonna double check that i didn't mess with a pin at the ecu, and have it tested tomorrow, but if that all turns out ok what can i do??
Old Sep 1, 2003 | 05:01 AM
VTECVillain's Avatar
Default Re: map sensor code 3 (DAMCOOLDAV)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DAMCOOLDAV &raquo;</TD></TR><TR><TD CLASS="quote">but if that all turns out ok what can i do??</TD></TR></TABLE>
Change the MAP sensor
Old Sep 12, 2003 | 07:28 AM
DAMCOOLDAV's Avatar
Default Re: map sensor code 3 (VTECVillain)
well i found a vacuum leak, i'm gonna redo the lines and **** and if that doesn't take care of it is there anything else i can try before changing the map sensor??
Old Sep 12, 2003 | 02:05 PM
FSTVTEC's Avatar
if you need a map sensor i have one for 60 + shipping
snidbits
Feb 11, 2011 03:19 PM
FSS13foxtrot
Jan 20, 2008 06:23 AM
Sci_v_icI
Apr 5, 2006 10:44 AM
Btothe3rdDegree
Dec 2, 2004 08:52 PM
barry11j
Aug 4, 2004 09:45 AM
