LSD INSTALLED? SPEEDO GEAR?
Old Oct 12, 2003 | 02:00 PM
d_mina's Avatar
Default LSD INSTALLED? SPEEDO GEAR?
I had a quaife LSD installed a few weeks back...after everything was done and installed..i realized my car went into limp mode ...then the shop realized they didn't install the speedo gear onto the quaife ...so here are my questions..
1. The speedo gear is that little gear that sits under the bearing right?
2. How do you get it off?
I have heard some people say that it is pressed on...other people say that you have to heat it up till it loosens up enough to come off and you have to get it on the quiafe before it gets cold? can someone who has done this already please explain...i've been stuck with this problem for awhile now...my ecu cuts me off at 6500RPM still have vtec at least..heh...but just not the same...you all know how that is...so PLEASE GIVE ME INFO ON THIS!!! THANKS!!
Modified by teameracer3 at 11:36 PM 10/12/2003
Old Oct 13, 2003 | 10:06 PM
d_mina's Avatar
Default Re: LSD INSTALLED? SPEEDO GEAR? (teameracer3)
went to honda today and got that damn speedo gear pressed off finally..what sucks is that while i was attempting to remove the speedo gear on my own...i thrashed up the bearing that sits on top of it not knowing that i was going to need that...ahh well...learn from your mistakes...thanks anyways H-T
mach3lude
Aug 29, 2011 07:18 AM
InfamousDC2FI
May 13, 2006 07:59 PM
Shmaa
May 24, 2005 12:52 AM
PupaScoopa
Apr 8, 2003 10:01 AM
Rodney
Jan 19, 2003 12:55 PM
