LS/Vtec vs. B20/Vtec?
Old May 10, 2010 | 08:20 AM
  #26
speedooo's Avatar
Default Re: LS/Vtec vs. B20/Vtec?
killing stock 03 mustang gts? b16 status!
9k on a stock b20 crank? haha
Old May 10, 2010 | 08:45 PM
  #27
kyosoeg6's Avatar
im really suprised to see that nobody has mentioned the use of the 84mm cast piston. last i knew it was made by/for rs machines and its like an itr replica only 84mm form. dont know the exact compression but i know its more than 11 but less than 12. i have a set that i bought years agon that im just now getting around to use. prostreetimport in la mirada still carrys this piston if i recall correctly
Old Oct 25, 2010 | 10:47 PM
  #28
low13da9's Avatar
so which one is better
Old Oct 26, 2010 | 09:45 AM
  #29
deucedeuceEK's Avatar
Depends on what is done to each motor. In short the b20 bottom end would be best. This entire thread tho is old and retarded.
Old Oct 26, 2010 | 11:20 PM
  #30
lunatics209's Avatar
lol
Old Oct 27, 2010 | 07:23 PM
  #31
andrewafdf1287's Avatar
i have a ls block ctr pistons a b16 head wit toda c2 cams, springs, and retainers farriea vlaves wat rods shoud i use
Old Oct 28, 2010 | 12:09 AM
  #32
92civiceg9gsr's Avatar
The B20's 84mm bore would unshroud the valves allowing slightly more efficient airflow into the cylinder.
Old Oct 31, 2010 | 05:20 AM
  #33
1904wrencher's Avatar
Both are good setup. Yeah, this thread is old. but, will never change. Until, K series so down.. Type R's are still pricey.Am doing my our Ls/vtec. But, thinking of buying A b20 to make a seperate motor.. Time and money.
Old Oct 31, 2010 | 05:23 AM
  #34
Damm, i need a spell checker..
Old Dec 14, 2011 | 12:50 PM
  #35
B20Wannabe's Avatar
B20 vtec all the way. Just gotta make sure it's done right and you'll be extremely happy.
Old Dec 15, 2011 | 05:11 AM
  #36
kyden's Avatar
why did you bump a thread from last year?
jarhead90crx
118
Jan 25, 2012 02:51 PM
VtecHusker
10
Jul 30, 2007 11:47 PM
tial-eg
11
May 7, 2006 04:02 PM
hondachris1994
Mar 24, 2006 07:18 AM
96LsBang
Jan 10, 2006 09:07 AM
