LS/VTEC Timing Covers? Which ones?
All,
I have a B18B and PR3 head hybrid and am looking to get the right parts for the timing belt covers.
I am looking to get the parts on numbers 1, 3 and 7 of the picture below! Not sure if they are from an LS, the GSR, Civic DOHC or a hybrid between them!!! Please advice what will be the right parts to get!
Thanks in advanced!
Thanks in advanced!
the lower timing belt cover you need on from the block you are using: ie if you have a b18b block with obd2 oil pump then you need an obd2 lower tbelt cover
b18a block with obd1 oil pump need an obd 1 lower tbelt cover
b18a block with obd2 oil pump need an obd 2 lower tbelt cover OR you can slightly modify the obd1 cover if you aren't running the CPK Sensor.
uppers i think you need the gsr or itr or ls.....forget where the 7mm height difference is made up between b16 and b18/b20 blocks
boosted k20
Oct 16, 2017 11:11 PM
