Ls Vtec problems
You could search, this is probably the most covered Honda Hybrid subject on the internet. At any rate you out to strengthen the bottom end of an LS block for high-rpm use. ARP rod bolts, VTEC oil and water pumps would be minimum, but a crank girdle wouldn't hurt either.
Yeah GSR oil/water pumps are good, I'll be using those for the B20 I'm putting together right now. But like I was saying, fix the weakest link which is the rod bolts, and using a GSR/ITR block girdle (requires also the oil pan & pickup) will probably suffice.
D-meet07
Sep 14, 2005 02:56 AM
mymeatb18"
Jun 4, 2005 11:24 AM
junya16
Jan 24, 2003 01:30 AM
