Ls/vtec help~! NOT STARTING.
Old Mar 23, 2006 | 07:44 PM
bOwEe's Avatar
Default Ls/vtec help~! NOT STARTING.
I JUST PUT IN A B18A N A B16 HEAD. EVERYTHING IS IN. IT STARTS BUT IT JUMPS FOR SOME REASON.. N WHEN I TRY TO CHANGE THE TIMING IT DOESN'T START AT ALL. ANY HELP?
Old Mar 23, 2006 | 07:49 PM
vtecspeed1320's Avatar
Shooting Star
dont need to caps it...what do you mean it jumps...from like 1000 to 1500? that is probably a vacuum leak just check and recheck all your vacuum lines.
Old Mar 23, 2006 | 07:50 PM
bOwEe's Avatar
Default Re: (vtecspeed1320)
ALL VACUMM LINES ARE IN.. U THINK TIMING OR BELT TOO LOOSE?
Old Mar 23, 2006 | 08:47 PM
redhondacivic's Avatar
Default Re: (bOwEe)
How does it run good/ bad. Are all plugs firing? MAP sensor and TPS have the right plugs?
Old Mar 24, 2006 | 02:51 PM
Shooting Star
You might have a vacuum leak still even if lines are in...a line could be frayed...however the eff you spell it....I plugged every vacuum port on my manifold. If switch the tps and map sensor hookups and see if it starts up and runs better. Any CEL'S ?
Old Mar 25, 2006 | 01:05 PM
I would run okay with a vacuum leak but if the plugs are switched no bueno.
Old Mar 26, 2006 | 03:56 PM
bOwEe's Avatar
Default Re: (redhondacivic)
okay now it starts. but right when i start it up it rev up to 6 quickly.. whats going on?
Old Mar 26, 2006 | 08:49 PM
7mile's Avatar
Default Re: (bOwEe)
throttle cable? can be anything... give more info
Old Mar 27, 2006 | 09:28 AM
bOwEe's Avatar
Default Re: (7mile)
olrite i got the reving to 6 rpm to stop.. now when i turn it on it idles up to 3 rpm constantly going up n down. i know its not the throttle cable.
Old Mar 29, 2006 | 07:01 AM
lsvtecracer's Avatar
Default Re: (bOwEe)
Sounds like a vacuum leak to me. spray carb cleaner around the tb and intake manifold gasket to see if you can find a leak. double check all the vacuum line going into the manifold.
facelift1
Feb 25, 2009 05:51 PM
civicflow
16
Jun 7, 2007 10:50 AM
Rev2 9K
Jan 21, 2006 06:27 PM
barry11j
Aug 4, 2004 10:04 AM
ls_vtec_b18a1
Oct 30, 2002 08:53 PM
