Ls/vtec and h2b quesion
Now i know theres already a thread for h2b's but i cant find an ls/vtec one so heres my question. In anyones opinion, what's easier. Ls/vtec or h2b. the thing is i already have a b16a3. So really all i would need are the blocks and of course the h2b kit if i went that way. But I'm just trying to find a good set up that's not gonna be so hard for me to do. I see a lot of altinator issues with the h2b as far as relocation but i hear that ls/vtecs arent reliable. I just can't make up my mind. I know an h2b will blow an ls/vtec out of the water and I'm not worried about that. I just want to know which one is easier.
Thats what i was thinkin. Thanks dude for the input. I don't think I'm gonna do either now that i think about it. I might just build my b16. Not many people do it so what the hell. But I'm still keeping my options open. Still need input though!
ls/vtec will be easier since you only need the block and gsr timing belt and head studs....you have everything else....h2b will be faster, but cost a lot more money as well and a lot more complex of a swap.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h2b_eg8 »</TD></TR><TR><TD CLASS="quote">ls/vtec will be easier since you only need the block and gsr timing belt and head studs....you have everything else....h2b will be faster, but cost a lot more money as well and a lot more complex of a swap.</TD></TR></TABLE>
Word. I've heard h2b's are well worth it though. But i dont want to be paying shops for labor. So I'm pretty sure I can do the ls vtec with a friend of mine. Now will I be able to rev to 8k on the stock ls block. Or will mods need to be done. Just curious. Cause i see guys talkin about their builds but nothing about where they can rev to.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h2b_eg8 »</TD></TR><TR><TD CLASS="quote">yeah ls bottom end wont hold to 8000 maybe with rod bolts, but even at that, you wot make power thathigh on stock cams/comp. so it will be pointless</TD></TR></TABLE>
Well now that you say that, I was planning on itr pistons and cams. What do you suggest for the bottem end for 8-82k?
dont rev it higher then needed....i dont know where you would make power to, get it dyno tuned and shift where the power falls off...makes sure a minimal of new rod/main bearings and rod blts if you plan revving that high.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h2b_eg8 »</TD></TR><TR><TD CLASS="quote">dont rev it higher then needed....i dont know where you would make power to, get it dyno tuned and shift where the power falls off...makes sure a minimal of new rod/main bearings and rod blts if you plan revving that high.</TD></TR></TABLE>
Alright sweet. Thanks dude. That was pretty helpful. I actually want to make power to about 8k. I was researching and itr cams aren't gonna cut it. I might go with moderately agressive cams. But once I start I'm gonna make a post on it so check it out.
Hey h2b_eg8. Would eagle rods with ARP bolts and je pistons require me to use an aftermarket crankshaft? Will I also have to resleeve the block for about 8500 rpm? Just want to be safe here.
What are some numbers to expect with a stock ls block with a b16 head with skunk2 stage 2 cams and valve springs and retainers? Just throwing that out there.
I priced everything out for my H2B swap already. Just waiting for my winter car to sell. I'm at about 3600 with a brand new motor, new gsr tranny, new fidanza flywheel,new clutchmaster stage 1 clutch, new avid mounts, and also factored in the prices to machine down the one pulley and buy a sohc alternator with the bracket. Basically EVERYTHING i needed without cutting corners and bolting up a nice drivetrain. The rest is just getting the crew together having a barbecue and swapping the beast in there.
