loom and OBD2A/B issue..
Old Mar 22, 2010 | 10:10 AM
60019184's Avatar
Default loom and OBD2A/B issue..
i have a facelift EJ6 which is OBD2B, D16Y7
I bought a loom from a pre-facelift (OBD2A, D16Y7) which has been converted to OBD1.
The loom, has a four wire 02 as standard, wired in the idle control modification..it has a OBD2a-OBD1 distributor harness, it has a conversion harness so you can run the p28 also, OBD1 injector clips have been soldered into place, wires have been lengthened and shorted to accomodate the side mounted throttle body..basically plug and play.
BUT will this work with my car as it was a OBD2B, if i was to put in a D16Z6?
Old Mar 22, 2010 | 10:14 AM
LA_HONDAS's Avatar
Default Re: loom and OBD2A/B issue..
no you cant use a obd2a engine harness in a obd2b car
Old Mar 22, 2010 | 10:16 AM
60019184's Avatar
so what would you recommend regards the wiring? is the whole loom is useless to me?
Ef88Lsvtec
Aug 9, 2008 04:54 PM
TGrant
Apr 19, 2006 02:25 PM
dw.VTEC
Aug 22, 2005 12:09 PM
JDM-97CX
Aug 15, 2005 08:54 AM
