leaking oil
Old Jul 19, 2002 | 09:37 AM
b20a1's Avatar
Default leaking oil
anyone have had problems with oil leaking with ls/vtec?
Old Jul 19, 2002 | 10:12 AM
SuperCivic's Avatar
Default Re: leaking oil (b20a1)
dude, you really shouldn't double post questions when you don't get immediate answers..try giving more info, like WHERE the oil is leaking from, or where you have evidence of the leak, ie, cam seals, head gasket, etc.
Old Jul 22, 2002 | 05:56 AM
Bleed Black's Avatar
Default Re: leaking oil (SuperCivic)
Mark, did you fix that yet? Did you find out if it is the oil line for sure?
Old Jul 22, 2002 | 10:54 AM
4drlsvtec's Avatar
yup, my lsvtec leaks very little it's normal..
I just finished doing my friends lsvtec, I put a thin layer of honda bond around the entire edge's of the headgasket where the oil returns back into the block...
The reason why it leaks is because the head is a little bigger'hangs over"
And the Ls block is a little smaller...
Doug 91' integ w/lsvtec
98GreenTegGSR
Dec 18, 2006 11:56 PM
jason190
Mar 31, 2005 08:12 AM
GruvyTune
Oct 24, 2003 04:05 PM
GruvyTune
Oct 16, 2003 09:20 PM
