Knock sensor wirring info
If i am using a gsr engine harness for my92 cx h22, being as though the gsr harness has a knock sensor will i still have to wire it directly to the ecu. Also I needed to know if i am using the gsr harness will i have to change injector clips to the prelude clips the harness is obd1
Thanks
Thanks
Yes you will have to wire it from the sensor to the ECU. Also if your H22 is OBD2 you will have to change over the injector clips from OBD1 to 2
