k20 weight?
i head k20 was a little lighter than most b series
EDIT- also the block is closer to the passanger side so it distributes wieght in the front- better for hanfling
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dveloped »</TD></TR><TR><TD CLASS="quote">k20 is about 30-40lbs lighter than a b-series</TD></TR></TABLE>
i never knew that. something learned today.
K20a swap is supposed to be about 20lbs. lighter than a B18C5 swap.
Also something interesting:
The TS-X has a magnesium tranny case which is light as hell!
If the issue is H22A weight vs. K20A weight - it's not contest.
B-Series engine/trans: 401 pounds
K-Series engine/trans: 403 pounds
(https://honda-tech.com/zerothread?id=879297)
EDIT: Sorry for bringing this post back from the dead!!!! i was searching around. whoops!!
My buddy just put a K20 in his 95 GSR he bought the car as a theft recovery, when installed, it sitts soooo much higher in the front. it looks like a fkn monster truck. i know that the tranny has to be heavier than a b series, simply b/c of the 6th gear. but everything else on the motor is alluminum(brackets and such) but overall the k is alot lighter than the b
