Motor is denting my hood
Does anyone know if they make like spacers for the hood or anything else to make my hood higher at the end, cause my motor is denting my hatch hood. lmk asap
Re: Motor is denting my hood (EJ8 DAVID)
If you do the washer thing you're also going to need longer bolts.
What part of the engine is hitting the hood? My friend's H22 swapped accord had the powersteering pump hitting the hood so he removed it.
Re: Motor is denting my hood (txdragon)
my buddies zc in his rex is hitting the hood, i know they make a special hood for that model year and engine combo
what motor, what car??? if its a b-series, it shouldnt be hitting the hood correct???
Re: Motor is denting my hood (dohcdelsol)
if its hitting the hood, that means your motor is not sitting properly the engine bay or you need new motor mounts
Re: Motor is denting my hood (Slow_import)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slow_import »</TD></TR><TR><TD CLASS="quote">if its hitting the hood, that means your motor is not sitting properly the engine bay or you need new motor mounts</TD></TR></TABLE>Or that the motor is just plain too big...
Just get some longer bolts and washers to replace the shorter ones on the brackets by the windshield. It'll be propped up in the back, but it probably won't hit anymore.
