JE pistons and eagle rods
Old Nov 17, 2003 | 09:12 AM
rudebwoy's Avatar
Default JE pistons and eagle rods
I sorta jump the gun and bought a set of je pistons and eagle rods made for a 1.8 integra 81.5mm bore, I have a b16a 81mm, I know all I need to do for the pistons is over bore .5 but what about the rods? will they be short enough to keep the 9.0.1 comp ratio, of the pistons in a b16 block, is the rods the same as b16?
Old Nov 17, 2003 | 09:47 AM
eyeamvic's Avatar
The rods for the integra is different from the b16. The b18c & b16b rod will NOT fit on the b16a crank. Rod length for b18c is 5.429" and the b16a is 5.29"
Old Nov 17, 2003 | 11:07 AM
rudebwoy's Avatar
it seems that they will bolt up to the b16 crank, the journals are the same, but will they be way way too long? will they even bolt up?
Old Nov 17, 2003 | 11:09 AM
rudebwoy's Avatar
I noticed the lournals are the same so how much longer are they will they even bolt up?
Old Nov 17, 2003 | 12:16 PM
eyeamvic's Avatar
Default Re: (rudebwoy)
It won't work unless you have the b18c1/5 or b16b crank. Any b-series rod will fit any b-series crank with the exception of the ones I just mentioned. In my case I wanted to see if I could get b16a rods/pistons for my b18c1, but I'd run into the same problem. I did the research before buying anything.
Old Nov 18, 2003 | 01:51 AM
rudebwoy's Avatar
will the b18 crank fit the b16 block without modification?
Old Nov 19, 2003 | 05:52 PM
ArinX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rudebwoy &raquo;</TD></TR><TR><TD CLASS="quote">will the b18 crank fit the b16 block without modification?</TD></TR></TABLE>
i dont think so,
the reason why i say this is because of the different heights of the two blocks. the block height of a b16 block is 263mm and the b18 block is 270mm
someone correct me if im wrong
Old Nov 19, 2003 | 06:48 PM
L-B racing's Avatar
Default Re: (ArinX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ArinX &raquo;</TD></TR><TR><TD CLASS="quote">
i dont think so,
someone correct me if im wrong</TD></TR></TABLE>
yu need to take 1/2 the crank throw when you try to figure out the block height. so a b16a is going to be roughly203-204 ish and b18's are212-213ish. hth
My Documents
Apr 18, 2011 03:39 AM
vtecn8ive
Feb 6, 2006 06:52 PM
draneusmc
Nov 13, 2004 04:32 AM
rogue3221
Jun 7, 2004 12:56 PM
BoostedSi
Apr 25, 2002 01:50 PM
