jdm motor passing smog?
i just pulled off a engine swap...its a jdm gsr motor...
im in socal.
its all stock so wat are my chances of passing smog?
what can i do or need to make this happen. thanks.
im in socal.
be professional
Re: jdm motor passing smog? (atmosphere)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by atmosphere »</TD></TR><TR><TD CLASS="quote">i just pulled off a engine swap...its a jdm gsr motor...
im in socal.
what can i do or need to make this happen. thanks.</TD></TR></TABLE>
You need all USDM emissions equipment including ECU, cat, and EVAP purge control solenoid and canister. The engine and OBD system must be the same year or newer than the chassis. Any mods must be CARB approved.
im in socal.
Re: jdm motor passing smog? (Targa250R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R »</TD></TR><TR><TD CLASS="quote">You need all USDM emissions equipment including ECU, cat, and EVAP purge control solenoid and canister. The engine and OBD system must be the same year or newer than the chassis. Any mods must be CARB approved.</TD></TR></TABLE>
Search, this is covered at least once a week... go ahead, go back a couple pages, I'm sure you'll find something.
yeah just put all the USDM smog stuff onto JDM motor, if its a good JDM motor it will have all the correct mounts for it all, or get ready to start some drilling...
o2 replacement (maybe)
everything except the evap purge solenoid.. you really dont need that ive seen people pass without.
https://honda-tech.com/zerothread?id=980331
perfect for you ?
perfect for you ?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by atmosphere »</TD></TR><TR><TD CLASS="quote">use equipment from the hx?
damn im selling everything for $350</TD></TR></TABLE>
Don't sell any of that until you pass smog.
