itr into EJ. A/C question. Good experience needed
I have a 00 jdm itr motor. I came witha compressor on it. I have a 95 civic ex. My friend got me a a/c braket from honda, but it was the wrong one, so I'm waiting on the right one (p54). I rather use the bracket and a/c compressor on the motor, because I dont want to delay the swap any longer. Is it possible to bend my current a/c line to match up with the itr compressor. How would I go about that. Someone mentioned they used del sol line bent them up. Can I do that with mine???
The end fittings that bolt to the compressor are different on the Civic lines so it won't work. You would need to make custom Civic lines with Integra ends for them to bolt to the compressor. Just wait for the bracket
You could also bend too much or break them too causing them not to work. Also has the ITR compressor been open to the open air for a while? If so, The compressor is prolly junk and I would waitinng for the p54 a/c bracket. And what Vtecvillian said too.
kylefakesi-r
Jul 8, 2007 10:10 PM
freakin_eLRoD
Jun 29, 2004 10:13 AM
