Intake manifold!!!!
Old Dec 18, 2003 | 06:27 PM
Shadow Templar's Avatar
Default Intake manifold!!!!
Ok, so Im wondering if anyone out there has an intake manifold preference, as in teamed up with throttle body, for best low, to midrange, or even high power. im plannin on maybe getting a skunk 2 after doin a mini me head swap on my D15B7. ill try to find a Z6 head, cause as far as i can tell, the y8 has more repercussions than benefits.
Old Dec 18, 2003 | 06:35 PM
VTECVillain's Avatar
Default Re: Intake manifold!!!! (Shadow Templar)
The Z6 manifold flows pretty well and you can always have one ported and polished. I'm a B Series person myself, so I'm not too sure on the aftermarket SOHC manifolds. The Skunk2 that a lot of people use on the GSR's are a good choice, maybe the SOHC would see similar benefits?
Old Dec 21, 2003 | 04:38 PM
Default Re: Intake manifold!!!! (VTECVillain)
Hey, I believe your right, but is port and polished better than an actual aftermarket specially desinged intake piece? Im not sure but i have heard there may be a difference in the SOHC and DOHC intake systems. Also, since ive put my cold air intake on, i have seen the check engine soon light come on on the highway at about 65-70, but it only happens once. Any ideas? I wasn t able to hook the line to eh block from the CAI yet, that couldn t be it, could it? thanks
Old Dec 21, 2003 | 05:10 PM
IS3Fifty's Avatar
yeah, thats it. you need to plug that vacuum line into the valve cover.
Old Dec 21, 2003 | 06:34 PM
Default Re: Intake manifold!!!! (TODAeg6)
Umm, now that I know, how exactly does the car realize that the vaccum line is out? just outta curiosity.
Old Dec 21, 2003 | 09:07 PM
Kamin's Avatar
its not really a vacuum line, its a recirculating line.
takes oil vapor that can accumulate in the valvetrain area and sucks it into the engine.
if you have excessive vapor your PCV valve needs to be replaced.
Old Dec 22, 2003 | 06:11 PM
Default Re: Intake manifold!!!! (Kamin)
Hmm, i hooked up the EGR hose...yet my check engine soon light still comes on...how do i find out what it is? must i take her to a dealership or some ****? my poor girl. ive heard from a few honda owners the light goes on after a few thousand miles for the reminder of maintenance. any truth behind that?
Old Dec 22, 2003 | 06:16 PM
Kamin's Avatar
no the CEL does not go on for maintance
reset the ECU and see if it comes back on, pull the ECU fuse for 1 minuet then put it back in.
Old Dec 22, 2003 | 08:08 PM
perhaps a stupid question, but izzat while the car is on or off? and is it marked ECU fuse? im so new to the honda technology.
Old Dec 22, 2003 | 08:52 PM
Kamin's Avatar
if you pull it while the car is running, it will shut off
and yes it says ECU somewhere on the underhood box diagram.
Nov 12, 2012 03:50 PM
Kris's turbo
Nov 5, 2009 06:28 AM
dseriessol
Dec 15, 2004 03:40 AM
Hyjnx
Oct 8, 2002 07:21 AM
