installed new axle.....problems..help
hey. I was forced to purchase and install a new (rebuilt) integra axle on my 89 civic. I broke my old 1 after installing the more agressive b16 tranny (took out the LS) so a week later i break my passenger side axle. Anyway. The new one was installed, and after that my car starts pulling right... a lot. Especially when i give it some gas. It doesnt pull that bad when its just in neutral. I assunme its either torque steer or my tires have worn to the old axle. What should i do? Rotate tires? if so from where to where? or should i hust gen another alignment, or will this go away once my tire wears to the new axle?
check your other axle. sometimes if you drive on a messed up axle (either side) you put more strain on the good one which eventually becomes damaged. i say replace the other one
i know this is OT but
what the **** DID YOU JUST SAY??!!
MY PARTA ASKIN ME AYE YO WHERE DA HOES AT? BUT F*CK WHERE DA HOES AT AYE YO WHERE MY CLOTHES AT? SEE DA DO OVA DERE YOU MIGHT WANT TO CLOSE DAT
