Idle too high! HELP!!
Old Nov 24, 2003 | 03:57 PM
daddymaxx's Avatar
Default Idle too high! HELP!!
Scenerio: 1997 civic hatch, with JDM Integra type r motor.
ok I don't know what's going on, I did my swap about 2 months ago and I've fixed EVERY problem except my high idle. I've set the idle using the proper way. (disconnect IAVC, set idle, utrn car off, plug back in, reset ECU) But to no avail. So now I have my idle screw turned all teh way down and it's at 1100rpm now....
When I set the idle to teh proper way it's up clsoe to 2000rpm.
I've checked my tps and it's perfect. I haven't checked teh map sensor yet though. how do I do that? Any other suggestions?
P.S. here's one more thing that is kinda interesting. When setting my idle, I unplugged hte IAVC, the idle RAISES, set the idle, then plugged it back in while the car is running. The car starts missfiring like crazy until I turn the car off and start it again...
Maybe I have my wiring messed up, but I'm pretty sure I have it right.
Old Nov 24, 2003 | 04:10 PM
VTECVillain's Avatar
Default Re: Idle too high! HELP!! (daddymaxx)
Are you throwing any CEL's? If not, check all of your vacuum hoses for proper connections and/or leaks.
Old Nov 24, 2003 | 06:09 PM
daddymaxx's Avatar
no CEL's and I near damn sprayed my whoel engine bay with brake clean looking for a leak..... nothing.
Old Dec 6, 2003 | 06:34 AM
hondalvr's Avatar
Default Re: (daddymaxx)
guys im having the same problem. my car idles at 800 rpms when i start it up in the cold mornings but when its at normal temp it idles at 1500 rpms.. im throwing a coolant temp sensor code 6 i replaced it with a brand new one and its still doing this.i put in a used TB,IACV,and fast idle valve.ive done everything from adjusting the TB idle screw to the fast idle.any help?
Old Dec 6, 2003 | 07:30 AM
its WANG yoO's Avatar
Default Re: (hondalvr)
mine is doing the same thing...
hondalvr...warm your car up and there is a bleeder screw on your thermostat housing..should be anyways...let the car warm up...not to hot but warm..when your temp gauge moves off cold..and crack that bleeder open..see if that helps
Old Dec 6, 2003 | 12:16 PM
hondalvr's Avatar
Default Re: (inJDMtegra)
ive tried that also but nothing.....ive tried everything i can think of and i cant find the problem,any help guys?
Old Dec 6, 2003 | 12:40 PM
ya someone help this kid...i need help too!
Old Dec 6, 2003 | 12:41 PM
hondalvr...how do you set the idle..maybe you could tell me everything you've tryed...so i could try and pin point my problem?
Old Dec 6, 2003 | 02:22 PM
hondalvr's Avatar
well i did the same thing they did.i have the timing checked.it was fine.replaced the iacv then the same thing,replaced the TB same thing,replaced the fast idle valve same thing,bled coolant same thing.
Old Dec 8, 2003 | 04:54 PM
norman's Avatar
this happened to my car i have a jdm motor swap i mess with the idle adjustment screw the reset the computer that how you do it
Old Dec 13, 2003 | 03:14 PM
daddymaxx's Avatar
nobody have any new ideas? Mine is different. If I set teh idle with the IAVC unplugged and everything . Then start my car again it's at like 3000 cold, then goes down to 1500. If I have the idle screw ALL TEH WAY DOWN. it warms up at 1600 and goes down to 1100 when warm.
And teh funny thing is if I'm costing down a hill and take my car out of gear, it only goes down to 1500 unless I come to a stop where it goes down to 100. that's same at lights and stuff.
Old Dec 15, 2003 | 09:24 AM
EE_Chris's Avatar
If you've got your IACV unplugged and your idle air bypass screw all the way in and you've still got a high idle, your looking for a big vacuum leak.
Did you mess with the throttle blade stop screw?
Have you adjusted your throttle cable?
Did you replace something on the intake side and re-use a gasket?
Re-bleed your coolant?
ECT connected and giving good signal?
TPS output voltage @ idle?
Old Dec 15, 2003 | 12:17 PM
hondaZvic's Avatar
Default Re: (EE_Chris)
i had all of those same problems, but i figured mine out...
i did all of the iacv stuff.
unplugged the sensor,
screwed that fast idle valve all the way in,
plugged the sensor back in.
it still didnt idle rite...
so.. i took the TB off, cleaned off the throttle plate,(it was sticking pretty bad), then i adjusted the throttle plate stop screw on the bottom of the TB(use an allen wrench and a 7mm open end wrench). put it all back together, adjusted my cable, and its perfect now.
no hesitation,
no crazy high idle
no low idle.
no surging...
jsut a smooth 8-900 constant.
Old Dec 15, 2003 | 12:20 PM
Kamin's Avatar
guys
you know when the car is cold its SUPPOSED to idle high around 1500 till the car warms up
hondalvr i think you have it backwards.
Old Dec 15, 2003 | 12:24 PM
hondaZvic's Avatar
Default Re: (Kamin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kamin &raquo;</TD></TR><TR><TD CLASS="quote">guys
hondalvr i think you have it backwards.</TD></TR></TABLE>
thats rite too.
i forgot to say, mine does this when its cold. 1500, then warmed up it goes back to 8-900.
it took such a load off my back when i finally got the idle fixed. it
dth0ng69
Mar 7, 2009 11:21 AM
JasonST
Jun 30, 2006 11:22 AM
DC2*Integra
Sep 20, 2005 12:51 PM
6969crx6969
Feb 29, 2004 02:59 PM
Civic Racer X 7
Jul 23, 2003 07:19 AM
