iat sensor plug different
Old Mar 19, 2018 | 05:26 PM
eddie7978's Avatar
Default iat sensor plug different
ok so my 2000 civic has a different style plug on my harness then the jdm b18c r.. the swap has the round plug in the manifold.. is it possible to depin and just swap the connectors? or are the pins different?
Old Mar 19, 2018 | 10:14 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: iat sensor plug different
The pins are different. Cut the wires to the plug in your hand with enough wire to reach the IAT sensor on the intake manifold. Then cut the other plug in the picture off 1" back from the black plug and connect the round grey plug to the newly cut wires... red/yellow to red/yellow and green/white to the green/black. Done.
Old Mar 20, 2018 | 03:05 AM
eddie7978's Avatar
sorry that other pic i had was wrong.. this is my iat sensor on the bottom and the itr has the circle one on top.. are these the same pins?
Old Mar 20, 2018 | 08:41 PM
JRCivic1's Avatar
10 Year Member
Community Builder
The pics don't change the answer... they are different, so cut and then re-connect as I stated above.
Old Mar 20, 2018 | 09:49 PM
holmesnmanny's Avatar
it's best to use the heat shrink type of butt connectors made by 3M that you can get in the electrical section at walmart
after crimping down good, use a lighter to heat up the ends and they will melt/shrink closed
Old Mar 21, 2018 | 03:08 AM
eddie7978's Avatar
do u know which wire goes to which side of the new circle plug?
Old Mar 21, 2018 | 03:12 AM
eddie7978's Avatar
really i always thought solder is better for the smaller wires?
Old Mar 21, 2018 | 10:14 PM
JRCivic1's Avatar
10 Year Member
Community Builder
OP, This answer is in my first response to your thread.
Old Mar 31, 2018 | 09:44 AM
HondaPartsHero's Avatar
Technical Hero
You could also just put the IAT into your intake arm
Old Mar 31, 2018 | 02:18 PM
eddie7978's Avatar
oh nah i have an itr intake manifold it goes on the manifold
Old Apr 3, 2018 | 03:48 PM
Technical Hero
Yeah doesn’t matter Honda updated it in 96 and put it in the intake arm and airbox. It’ll be fine. Just use your OBD2 sensor and put it into your intake arm
Old Apr 3, 2018 | 09:31 PM
JRCivic1's Avatar
10 Year Member
Community Builder
The sensor range in manifold is far greater than what you would experience if the IAT is mounted in the inlet tube. So, if you intend to use an OBD-2 ECU, I would agree with HPH and mount it in the inlet tube. However, if you intend to use a tunable OBD-1 style engine management system, I recommend altering the plug and connect to the IAT sensor found in the intake manifold.
Bjm1118
Mar 17, 2019 11:51 AM
chrisfromsrq
Jan 24, 2010 08:37 AM
prox25
26
Oct 13, 2009 11:57 AM
jwbnavy
Dec 4, 2007 02:20 PM
RAS Motorsports
Jul 10, 2003 11:52 AM
