iacv code 14!? code 20 ELD!? and 41 o2 heater!?
Old May 21, 2003 | 02:23 PM
2trix's Avatar
Default iacv code 14!? code 20 ELD!? and 41 o2 heater!?
got my tps code gone! now i can rev the dam thing but its cuttin out in the top end due to that dam o2 code i believe!? havent tried a new o2 yet...what else could it be...its wired like stock just has extended wiring...the set up is 95 h22 in 96 civic with p28 ecu (chipd) with stock dx harness...also im getting iacv code in which ive run power to the lower wire in the harness and ran directly to the blk/bl and im still gettin the dam code...also my idle is super low..like 450-500...could this be too low for the iacv to bring idle to its correct state thus giving me the code? also on my p13 throttle body i cannot find the idle screw!? my TB has the map on top instead of mounting to the firewall!? any ideas? and then on my eld my alternator is not putting out an juice...just gettin it, could this cause the eld code!?
Old May 21, 2003 | 03:42 PM
2trix's Avatar
Default Re: iacv code 14!? code 20 ELD!? and 41 o2 heater!? (2trix)
i guess noone can hear my crays of pain....i have searchd this many times and can never come up with a straight answer on what i can do...i know all situations and set ups are diff and react diff but id really like some input....
...oh yah....bump!
Old May 21, 2003 | 03:52 PM
roc's Avatar
roc
is your intake air temp.sensor hooked up
Old May 21, 2003 | 04:52 PM
2trix's Avatar
Default Re: (roc)
sorry not that much of noob! iat is fine...i did try to switch just in case..but then i threw iat code...so...im kinda stuck!?
Old May 21, 2003 | 05:45 PM
Newman's Avatar
New User
Take your IACV off and clean it up really good with some brake cleaner and some WD40. Then use Hondabond around the gasket and put it back on. If you can't find your idle screw, make sure it's even still there.... I've seen it "rattle" out before so make sure you have it in there (usually to the 11:30 position from the center of the TB openning, and you'll see a screw that's requires a flat-head screwdriver). If you don't have one in there, then you have a good vacuum leak there. As for the alternator, make sure everything is being grounded properly. When you said it's getting juice but not going anywhere, that means there's a break in the circuit, and not grounding and completing the circuit.... that should fix your ELD code. Make sure you used shielded wires for the O2 sensor and didn't have any breaks in the wires.... also try a different one. While doing all of this, have your battery unplugged, and that'll reset the ECU and you can go from there.
Old May 21, 2003 | 06:01 PM
2trix's Avatar
Default Re: iacv code 14!? code 20 ELD!? and 41 o2 heater!? (Newman)
alright newman ill see what i can do! with the harness i solderd all connections and used heat shrink..i did not howver extend the shieldd wire on the o2...i also cleand the iacv but did not bond the seal...well see how it goes!
Old May 21, 2003 | 08:50 PM
Jackson's Avatar
Did you switch the pin from a14 to a12 on the ecu side of the harness?
Old May 21, 2003 | 09:24 PM
sparkz's Avatar
iacv, o2 heater circuit share the same power source which is located in this distribution block
did you wire up a resistor box?
Old May 22, 2003 | 10:07 AM
2trix's Avatar
Default Re: iacv code 14!? code 20 ELD!? and 41 o2 heater!? (sparkz)
for injectors i wired inline resistors...not a box. i get power to the iacv and i get power comming out as well...havent chkd on power to o2 yet...figured out that i had the secondary o2 wired and not the primary...changed this and still get 41? also i did find the idle screw right below the map to the left on the TB...its adjusted as far left as i can go...the slot is horizontal and the idle is still ***! im runnin outa ideas here...im gone for the weekend but when i get back im gonna chk the ohms on my o2 to see if its even working....i did clean the iacv bonded the seal and made sure that i have power and that the blk/bl wire is goin to the correct location.. with the conversion harness to obd1 the blk/bl wire is goin to the blk/bl... i dunno.....ill triple chk when i get back home...
Old May 22, 2003 | 10:24 AM
sparkz's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2trix &raquo;</TD></TR><TR><TD CLASS="quote">for injectors i wired inline resistors...not a box. i get power to the iacv and i get power comming out as well...havent chkd on power to o2 yet...figured out that i had the secondary o2 wired and not the primary...changed this and still get 41? also i did find the idle screw right below the map to the left on the TB...its adjusted as far left as i can go...the slot is horizontal and the idle is still ***! im runnin outa ideas here...im gone for the weekend but when i get back im gonna chk the ohms on my o2 to see if its even working....i did clean the iacv bonded the seal and made sure that i have power and that the blk/bl wire is goin to the correct location.. with the conversion harness to obd1 the blk/bl wire is goin to the blk/bl... i dunno.....ill triple chk when i get back home...</TD></TR></TABLE>
41 is definately heater circuit and most likely you have an open somewhere in that circuit. also sounds like you might only be on 3 cylinders? is your idle rough?
Old May 22, 2003 | 12:04 PM
2trix's Avatar
idle isnt too bad. im not throwin any misfire or dist. codes....the car will rev now, just not in the top end. the idle is low....hmmm...i dunno. ill chk and make sure all cylinders are getting spark!...what it seems is that im runnin too rich in the top end due to o2 not working right and its not combusting all gas in the cylinders...im gettin a good amnt of black smoke in the top end.
edit: also ran shieldd wire coming off the white wire on the o2...blk/wht to blk/wht, blk/ylw to blk/ylw and grn/blk to grn/blk!? ill see if im getting power to the o2.
Old May 22, 2003 | 12:32 PM
sparkz's Avatar
under WOT, it wont make a difference performance wise if your o2 was hooked up or not.
Old May 22, 2003 | 12:59 PM
2trix's Avatar
hmmm...then i dunno?.....this is drivin me crazy! all i did was extend wires...there should be no break in the loop!
Old May 22, 2003 | 02:09 PM
Nextelbuddy's Avatar
well my car was thowing codes and was not reving high and i replace the CAT and everything was back to normal
Old May 22, 2003 | 02:35 PM
Jonathan_ED3's Avatar
I'm still throwing 41 as well.
Wiring is perfect. All wiring is shielded. I've quadruple checked everything.
I've tried three different 02 sensors and it's still throwing 41. Cat is brand new too.
I feel your pain manG
Old May 22, 2003 | 03:06 PM
Jackson's Avatar
If you are using your stock dx harness, you will need to switch the pins like I already said. Even if you are running an ecu jumper. That will fix your iacv problem, guarenteed.
Modified by Jackson at 1:01 AM 5/23/2003
Old May 22, 2003 | 04:49 PM
2trix's Avatar
Default Re: iacv code 14!? code 20 ELD!? and 41 o2 heater!? (Jackson)
well ill try to run directly from the iacv to ecu and see if will work!?...what about ELD code ol mighty wizard!?....but isnt the point of a conversion harness to convert!? thanks jackson ill take a look and see if that works...im sure it will..itll bring my idle up and make me happy...now if i can just get that dam o2 right!?
commotion
10
Jun 11, 2007 03:38 PM
GruvyTune
Nov 4, 2003 07:42 PM
