How to check CEL?
Old Jul 13, 2005 | 03:30 PM
fwdtamiya's Avatar
Default How to check CEL?
I've got an H22 swapped, 93 Civic. How do i check the CEL. I heard i could use a paper clip somewhere, and it would blink a certain about of times, and that would atleast give me the code. Any help would be greatly appreciated.
Also, it comes on only after the car has warmed up a bit, and my car doesn't like to start when it gets anywhere near warm outside
Old Jul 13, 2005 | 05:11 PM
Hapexamendios's Avatar
Default Re: How to check CEL? (fwdtamiya)
https://honda-tech.com/zerothread?id=1171263
Old Jul 13, 2005 | 06:56 PM
fwdtamiya's Avatar
Default Re: How to check CEL? (Hapexamendios)
Thanks! Now do i need a copper wire, or will anything conductive work? And what are the codes listed that go beyond just numbers? Like this "P0010"
Modified by fwdtamiya at 8:26 PM 7/13/2005
Old Jul 14, 2005 | 07:37 AM
EE_Chris's Avatar
Yes - anything conductive. A paperclip works like a champ.
The P codes are OBD2 specific codes. Even though all 96-00 Civics are OBD2 and still spit out the blink code you get using the jumper method, if you had a scantool you could get access to those P codes.
And further, P0xxx codes are general OBD2 codes while P1xxx codes are manufacturer specific.
Old Jul 14, 2005 | 12:44 PM
fwdtamiya's Avatar
Default Re: How to check CEL? (EE_Chris)
Thanks
aldaman
Apr 2, 2009 05:18 PM
duh blacksheep
Jun 5, 2005 08:16 PM
WhiZa
Oct 26, 2004 06:07 AM
TyPE-RON
Nov 4, 2002 04:34 PM
