hesitation problems with b20 crx
Old Jan 16, 2003 | 10:00 PM
Brad's Avatar
Default hesitation problems with b20 crx
When I press the throttle from a stop, the car hesitates like it really slowly moves, then all of the sudden accelerates like normal. It happens a lot, but not all the time. What could be the problem? TPS voltage measures .45V closed, and I'm using a b16a fpr. Would a too low fuel pressure cause the hesitation? Also, the timing is at 12 degrees because it's turbo'd, would raising to like 14 help?
Thanks,
Brad
Old Jan 16, 2003 | 11:59 PM
PinkDelSolonDaisyWheels's Avatar
Default Re: hesitation problems with b20 crx (Brad)
Um I would have ur timing checked out.... Now does it feel like its boggin down when u try to acclerate or does it feel like theres no fuel gettin 2 the engine at all?
Old Jan 17, 2003 | 07:03 AM
misledyouth's Avatar
New User
Default Re: hesitation problems with b20 crx (CivicStyleHB)
i would definatly check the timing and fuel presure. also check your plugs and if that fails check map and tps. TPS would be a throttle responce thing for sure so i would check the ohm out put of that to make sure it's workign.
jesse
Old Jan 17, 2003 | 07:14 AM
Brad's Avatar
Default Re: hesitation problems with b20 crx (CivicStyleHB)(misledyouth)
It feels like the car is moving super slow. I'm not sure how to differentiate between bogging and no fuel, but it does feel like it's very very slowly accelerating then after a couple seconds accelerates normally. Do you think the timing might be off or would 12 degrees be too low?
Is there a difference between checking the voltage and ohms? Do I just measure it in a closed and wot throttle to see if it's working? And would you know the correct fuel pressure for a b20?
thanks.
[Modified by Brad, 8:17 AM 1/17/2003]
92slamed4door
11
Feb 28, 2011 09:24 PM
boosted20psi
Jan 15, 2011 10:40 PM
AllMotorHB
39
Sep 24, 2010 12:41 PM
zensoku207
Mar 21, 2005 10:49 PM
11secdx
Dec 26, 2001 08:20 AM
