Help w 92 hatch
Old Apr 5, 2002 | 04:25 PM
joeyitr309's Avatar
New User
Default Help w 92 hatch
I am trying to put a 99 b16a in to a 92 dx hatch and everybody keeps telling me I need a new distributor. What exactly do I need and where can I get it. What ecu do I need also?
Thanks
Old Apr 5, 2002 | 04:26 PM
poison's Avatar
Default Re: Help w 92 hatch (joeyitr309)
u should use an OBD1 ECU (probably del sol vtec ecu) not sure if those come in OBD1, as for distributor, you wouldn't need a new one unless urs is bad.
Old Apr 5, 2002 | 04:27 PM
joeyitr309's Avatar
New User
Default Re: Help w 92 hatch (poison)
They told that the wire harness on the 92 hatch will not work with my 99 distributor
Old Apr 5, 2002 | 05:19 PM
VTECVillain's Avatar
You will need a Del Sol DOHC VTEC or a JDM SiRII OBDI ecu. You could also use a 92-95 P28 (Si or EX) ecu that's reprogrammed, which would be much easier to get. I have a 92 VX with a 99 B18C1 motor and I'm using the 99 distributor. If you get the harness with the motor then you can use the distributor and injectors since you'll have the plugs.
Old Apr 5, 2002 | 05:21 PM
joeyitr309's Avatar
New User
Default Re: Help w 92 hatch (VTECVillain)
Thanks!!
heopmarine
Feb 6, 2015 11:24 PM
bmoney
Nov 21, 2005 08:40 AM
sloweredcivic
Feb 11, 2005 09:10 PM
ImThatGuy
Dec 3, 2004 05:05 PM
milton
Nov 2, 2004 10:24 PM
