HELP!!!!! TransMission?? or Vtec??? or ECU????
Old Sep 1, 2004 | 05:03 PM
maka's Avatar
Default HELP!!!!! TransMission?? or Vtec??? or ECU????
Here is the deal:
I have a 90 Acura Integra w/swap, B18C3 (euro gsr, or R dont know) anyway. I purchased the car with the swap and it has a B16 cable tranny. The PROBLEM is, my car revs pretty high. Meaning, when i am in 5th gear, going about 80mph, my car is up in the 5k rpm. When I floor the throttle it goes, dont get me wrong, but it dies at 7k rpm & 110 mph as if i had a governor.
My car revs till 8k rpm cause of the euro spec, but anyway i dont know if it is a Vtec problem, or a transmission problem, or could it be an ECU problem. . Any info would help me out thanks H-T.
P.S. I have a obd0 Ecu...
____or____ could it be a knock sensor?
Modified by maka at 2:18 AM 9/2/2004
Old Sep 1, 2004 | 05:23 PM
ATS*Mark's Avatar
OG triple OG
Default Re: HELP!!!!! TransMission?? or Vtec??? or ECU???? (maka)
what chip are you running maka?? are you sure its obd0 or is it converted to obd1????? find out what ecu are you running . transmission is not the problem . you can rev the gears to 8k in the other 4 gears but it only goes to 7 in 5th and cuts out at 110? sounds like fuel cutoff to me
Old Sep 1, 2004 | 05:24 PM
ATS*Mark's Avatar
OG triple OG
Default Re: HELP!!!!! TransMission?? or Vtec??? or ECU???? (Hella_JDM)
knock sensor only retards timing when it senses knocking , and also adds fuel . but wouldnt cause this problem
Old Sep 1, 2004 | 05:27 PM
maka's Avatar
would it be a obd1 prob if it is obd1? what is the difference obd1 obd0. he said he has obd0
Old Sep 1, 2004 | 07:02 PM
igy's Avatar
igy
Sounds like speed limiter to me. 180km/h(112mph)
Old Sep 1, 2004 | 07:13 PM
ATS*Mark's Avatar
OG triple OG
Default Re: HELP!!!!! TransMission?? or Vtec??? or ECU???? (igy)
do pre obd have limiters tho?? i was under the impression that they didnt
Old Sep 1, 2004 | 10:06 PM
Slopoke's Avatar
I believe the obd0 ecu's do have the speed limiter.
Old Sep 1, 2004 | 10:12 PM
maka's Avatar
Default Re: HELP!!!!! TransMission?? or Vtec??? or ECU???? (Slopoke)
limiter @110mph.. no! that sucks. guess i am swapping to obd1
Old Sep 1, 2004 | 10:13 PM
ATS*Mark's Avatar
OG triple OG
swap to obd1 like we talked about , and that guy i told you about can send you a program with no speed limiter on it
Old Sep 2, 2004 | 05:39 AM
S@nt0s's Avatar
Munkyw3rkz.webs.com
well your at 5K in 5th at 80mph becuase of the tranny's gear ratio...in the GSR im at 4k at 80....
im pretty sure OBD0 ecu has a speed limiter...i say convert to OBDI and chip that shitsssssssss
notorioussabo
Sep 13, 2008 06:28 PM
nickcrx
Oct 18, 2005 08:45 AM
krazie1
Jan 21, 2004 10:16 PM
90civichbsi
28
Sep 19, 2002 08:08 PM
